2
This discussion topic has been answered Discussion topic: Sky q box catch up or on demand not working
This message was authored by: Steve86
Catch up and on demand not working on sky q . Get message saying i have to upgrade subscription
Avatar for Steve86
This message was authored by: Steve86 Answer
Re: Sky q box catch up or on demand not working
Thanks for advice. Had to call sky help line they reset something at their end which dolved problem. Thanks for your reply
hi @Steve86
Are you a new customer or recently made changes to your subscription or similar ?
Do you have the HD add on - if not then note the following:
The default download quality is set to HD (high Definition) not SD so when you try to download and watch you are prompted to upgrade (i.e. take out the HD subscription)
So if you don't have the HD add on you just should try changing your download preference to SD
Main Menu -> Settings -> Setup -> Preferences
(Please note this setting can only be set on the Main box)
Avatar for Steve86
