Discussion topic: Sky q box and sky qbox mini havent worked all day. Weve switched off checked leads and still nothing
Message posted on 14 May 2024 05:18 PM
Not had tv all day in the lancs area. Both q boxes will not connect to the home screen. We've done all the checks and nothing. Having to watch something on Amazon
Message posted on 14 May 2024 05:21 PM
Re: Sky q box and sky qbox mini havent worked all day. Weve switched off checked leads and still not
Hi @Spenny65
Reboot the mini as above.
