Discussion topic: Sky picture is scrambled and no signal
This message was authored by: Jasper2018
Sky box is scrambled picture is not right on most channels
Re: Sky picture is scrambled and no signal
Hi @Jasper2018
If this doesn't help it's best to contact Sky for an Engineer to check your dish.
