3
This discussion topic has been answered Discussion topic: Sky only displays in small window on my smart tv
This message was authored by: peteb1
This message was authored by: Laing1 Answer
Re: Sky only displays in small window on my smart tv
@peteb1 Have you tried rebooting your  Q box ie
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
@peteb1  Have you checked your TV's own settings?   As we don't know what TV you have you'll need to read the TV's user manual.
Avatar for peteb1
Thanks, resetting work ( I had switched I off and on but not waited 30 seconds
Answered - Go to Answer
