Discussion topic: Sky on high rise block
Message posted on 27 May 2024 02:57 AM
Hi is it possible to get Sky Q on a high rise block of flats, 7th Floor. The floor accomodates upto 7 floors. Is it possible to get Sky Q, any luck anyone.
Message posted on 27 May 2024 05:30 AM
Re: Sky on high rise block
Have you asked your neighbours? Have you contacted your building management company or landlord to ascertain if they
a) have a communal dish for residents and what does it provide
b) allow individual satellite dishes should you have a balcony with a suitable position for a dish with the required line of sight
NOTE: I only provide help on the forum boards and NOT via Direct Messaging so DMs are switched off
Message posted on 27 May 2024 08:41 AM
"The floor accomodates upto 7 floors"
