Discussion topic: Sky not working sky box won’t turn on and when it does it says no signal
This message was authored by: Philrace3181
Sky not working box won't turn on or off and when it does eventually come on sky is not working
Re: Sky not working sky box won’t turn on and when it does it says no signal
Hi @Philrace3181
First try rebooting your Q box.
If you had to press the Standby button (Amber led) on the front of the Q box to turn the Q box on;
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Avatar for Philrace3181
Level 0 icon
I've tried this but will try again
