Discussion topic: Sky not working on tv and multi room
This message was authored by: Stephen+Thorpe
Since 9 pm sky isnt working. Multi room message there has been a pribkem findung your sky q box on the network. Phones also stopped working.
Re: Sky not working on tv and multi room
Hi @Stephen+Thorpe
Reboot the mini as above.
