Discussion topic: Sky not working in bedroom now
Message posted on 14 May 2024 11:28 AM
Sky not working in bedroom. Says waiting for tv schedule. For the last few days had no signal
Message posted on 14 May 2024 11:31 AM
Re: Sky not working in bedroom now
Hi @Dawn541
Reboot the mini as above.
