Discussion topic: Sky not showing on TV
Message posted on 16 Sep 2024 04:55 PM
My TV has a message on it saying 'this screen does not support HDCP.
Try reconnecting your HDMI cable, or use a different screen.
I tried reconnecting the HDMI cable but get the same error
Message posted on 16 Sep 2024 05:09 PM
Re: Sky not showing on TV
Did it used to work and stop?
Message posted on 18 Sep 2024 10:32 AM
It used to work, this message appeared for the first this week
Message posted on 18 Sep 2024 10:34 AM
Hi @Clive66
First make sure that the TV is switched on and is switched to the HDMI input to which the Q box is connected.
Then with the Q box switched on with green led illuminated
Press
Home 1 0 8 0 Home
on the Q box remote control.
This will change the Q box to standard resolution which will work for all TV’s.
