Discussion topic: Sky not helpful with making payment arrangement
This message was authored by: Ruffruff365
Have just rang Sky Customer Services due to not being able to pay this month's bill until 24th as had to take unpaid leave as needed to look after my partner after a major operation & they are not willing to help.
Re: Sky not helpful with making payment arrangement
@Ruffruff365
Sky have to obligation to and the payment and restriction process is automatic anyway. This is the billing process which applies to us all…
▪️If you have a Direct Debit set up and the payment fails on the normal payment date Sky will automatically attempt it again 10 calendar days later (so DO NOT be tempted to make a manual payment in this period).
After 10 days, if that second attempt also fails Sky may send a text and/or email notifying you that your payment has failed again and you then have a day or two before they restrict your services.
▪️If you have a Continuous Card payment method set up, if the payment fails Sky send the text/email notification about the failed payment and you usually have at best 2/3 days before being restricted. There is no grace period and I believe only 1 attempt is made for a card payment, so if this has failed, you will need to pay manually and then reset the payment method for next month.
Restrictions are an automated process and we’ve been told Customer Service agents can’t stop it… even if you’re told otherwise.
Sky don’t allow payment plans (except on a legitimately closed account) or a promise to pay on or by a certain date.
This link may also provide some advice
https://www.sky.com/help/articles/cost-of-living-support
If you are behind with Stream or Glass payments also see the information on this link:
https://www.sky.com/help/articles/missed-payments-sky-glass
