Discussion topic: Sky not connecting to tv
Message posted on 01 Aug 2024 04:35 PM
We have recently moved our Sky box and since then it hasn't been working properly and won't connect to the tv.
We have tried shutting it down and restarting and we've checked the cables are in properly but nothing is working.
Message posted on 01 Aug 2024 05:54 PM
Re: Sky not connecting to tv
Hi @John336
Assume this is your main Q box?
What did you do about the Two Dish cables in the Q box.
Did they reach the new location of your Box?
Message posted on 01 Aug 2024 06:02 PM
We got an extension shotgun lead was working fine but now connection dropping in and out and can't get recordings up
Message posted on 01 Aug 2024 09:43 PM
Hi @John336
Have you tried completely reconnecting the main Q box since you moved it?
