Discussion topic: Sky multiroom not connecting to sky q
Message posted on 29 Sep 2023 06:42 PM
Spoke the someone in technical regarding speed issues. He suggested that I should reset my router so I have done so and ever since my multiroom boxes will no longer connect to the Q box
Message posted on 29 Sep 2023 07:42 PM
Re: Sky multiroom not connecting to sky q
Have you done a "start again from scratch" on them?
Message posted on 29 Sep 2023 07:57 PM
Hi @Amz287
Reboot the mini as above.
