Discussion topic: Sky minibox losing internet connection. Unusable. Sky automated helpline is u helpful amd cuts you o
This message was authored by: SkyCustomerDIY
I try to call sky about a broadband issue but they direct me to a public forum while increasing my price. My mini box upstairs is no longer connecting to the Internet.
Re: Sky minibox losing internet connection. Unusable. Sky automated helpline is u helpful amd cuts y
Hi @SkyCustomerDIY
Reboot the mini as above.
Avatar for SkyCustomerDIY
Thank you for the prompt reply. I've tried all of the above except a booster. The issue occured on Wednesday last week. Been ok for a couple of year's. Need sky to help diagnose the line possibly as the Sky Mini box says connected to router ok, but the Internet item has a cross, then flicks to a tick, then goes back to a cross.
It's a Q issue, not a broadband issue. Try the steps in post 7 in the thread below and also have a look at the link in post 8.
wifi networks are dynamic, partly due to interference sources changing over time, partly due to the Q's "clever" networking doing stupid things, so the fact it worked for a couple of years is sadly no guarantee it will stay like that.
https://helpforum.sky.com/t5/Sky-Q/Sky-q-box-not-linking-with-Wi-Fi/m-p/4504698#M618552
I'll give it a go when I am back home as I'maway until Friday now leaving the house with no working Minibox, thanks for digging out the associated post.
For visibility of Sky: Very disappointed customer that Sky are not available on hand when I tried to get hold of them yesterday during their opening hours and pointed me to a community forum. Seems a very strange way to self-serve a complex issue. Now the issue is prolonged over multiple days exacerbating the frustration and disappointment.
Thank you.
Normally you can persevere with the phone system to get through to a human.
but agree it's a cost cutting tactic. The joys of capitalism and the eternal demand for profit growth.
