Discussion topic: Sky mini q boxes says I need a subscription to watch any channel
Message posted on 03 May 2024 10:23 AM
I have checked and I have the subscription for multi room and everything active.
I have tried disconnecting from mains, reconnecting to the main box, updating the software and nothing seems to work. There is an engineer coming but not for another week and i really like to try and have it fixed by sunday if possible, wondering if there's anything i can try to fix it before the engineer comes?
Message posted on 03 May 2024 10:29 AM
Re: Sky mini q boxes says I need a subscription to watch any channel
Hi @Harvey1881
When the main box is completely back up and running
Try refreshing your Viewing card.
Home - Settings - System info.
Highlight Viewing card number and then select Setup on the right hand side.
Then select Use this option to trigger a callback
No call is actually made but the Viewing card should be refreshed.
Finally reboot the mini again
Message posted on 03 May 2024 11:00 AM
thanks for replying, unfortunately this doesnt seem to have worked 😞
Message posted on 03 May 2024 11:03 AM
Looks like you need Sky to reset your Viewing card @Harvey1881
Message posted on 03 May 2024 11:10 AM
ok thanks for your help 🙂
