Discussion topic: Sky mini boxes say waiting for tv schedule continiously
This message was authored by Martinkop1 This message was authored by: Martinkop1
My 2 sky mini boxes say waiting for tv schedule continiously .
I have rebooted my broadband and rebooted all the sky Q boxes.
all the boxes have the ticks on to say it's working ok.
my main box is working fine .
thanks
martin
Re: Sky mini boxes say waiting for tv schedule continiously
thanks
martin
Have you tried reconnecting them to your Q box @Martinkop1
Try a Network Reset on the minis.  Start with the one nearest to your Main Q box.
As you are on Sky Broadband if the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button.
When you carry out the Network reset on the second mini you can use the first mini for WPS if nearer than the main Q box.  Follow the same procedure for other mini.
Failing all of the above you may need a Sky Q WiFi Booster to position between the main Q box and the minis.
Martinkop1
Thank you, all sorted now .
thank you for the help
