Discussion topic: Sky mini boxes not working since broadband upgrade
This message was authored by: Al69
Getting error code mr104 on boxes and when checking the subscription  error code dsu508.
Re: Sky mini boxes not working since broadband upgrade
@Al69 who is your current broadband provider and has it changed recently as MR104 is normally due to your mini boxes not getting a signal.
If you have changed from Sky to a third party broadband provider you mini boxes need to be connected to your main Q box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Hi @Al69
Reboot the minis as above.
If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or previously connected mini).
