Discussion topic: Sky mini boxes not working, all saying no satellite signal
This message was authored by: Ray114
My three sky mini boxes are not working all three are saying no satellite signal. The main sky a box and TV is working but none of the mini boxes are working and they are all connected to the internet.
Re: Sky mini boxes not working, all saying no satellite signal
Hi @Ray114
Reboot the minis as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router (not Sky Max) if on Sky Broadband or previously connected mini).
