Discussion topic: Sky mini boxes not connecting to new replacement skyq mainbox
This message was authored by: Bigron1
Today I had a replacement sky q box due to a hard drive failure. I also have three mini-boxes, the first is positioned downstairs in the back lounge which is next to the room where the main skyq box is positioned. this is ok, but the two mini-boxes upstairs one did connect but then dropped out and will not reconnect. the last box did not connect at all. When the original skyq box was working everything with the mini boxes was ok. how can I get these mini-boxes working without calling out the engineer once again?
Re: Sky mini boxes not connecting to new replacement skyq mainbox
Hi @Bigron1
Reboot the minis as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router if on Sky Broadband or previously connected mini).
