Discussion topic: Sky mini box won’t connect to main box
This message was authored by: Wendy67
3 days ago my upstairs mini box stopped working. Despite every reset on all boxes, multiple times over the last few days, router restarts etc nothing is fixing it. Sometimes it says there's no network connection (I have sky broadband) despite everything else in the house, including my main box, working fine with the internet, sometimes it says it can't connect to main box. Occasionally it will work but really intermittent so cuts out all the time, then goes back to saying no network or can't connect. I've tried everything suggested and I'm at the point now I want to throw it out the window!!!! Please can someone help
Re: Sky mini box won’t connect to main box
Hi @Wendy67
try a Network Reset on the mini.
