2
This discussion topic has been answered Discussion topic: Sky mini box will not play tv shows, but will work with you tube
This message was authored by: baj09411
The mini box shows all channels and the tv screen is solid blue, the tv cycles over and over. And will not work, l am unable to record any shows and will not download, l have tried to rest mini box by disconnecting from the main power for 1 to 2 minutes but fault is still the same
This message was authored by: Laing1 Answer
Re: Sky mini box will not play tv shows, but will work with you tube
@baj09411 Have you tried rebooting your main Q box ie
then
reboot the mini box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
then
reboot the mini box
Avatar for baj09411
Good morning Laing1
thank you for update, l tried your suggestion and now tv working fine
thank you
