Discussion topic: Sky mini box saying no signal
This message was authored by: Michael1207
All of my sky mini boxes are saying no signal. The main box is working ok. I have checked settings/status and both network and sky Q box are ticked?
Re: Sky mini box saying no signal
Hi @Michael1207
Reboot the minis as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router if on Sky Broadband or previously connected mini).
