3
This discussion topic has been answered Discussion topic: Sky mini box saying no sigal
This message was authored by: Beaniesghirl
Mini box saying no signal. Turned on and off few times. Main box saying connected
Re: Sky mini box saying no sigal
@Beaniesghirl wrote:
Main box is saying it's connected but mini box has red light on
Hi @Beaniesghirl
Have you tried switching the mini on using the Standby button on the front right of the mini (the Amber led)?
If this turns the mini on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
@Beaniesghirl
No signal message normally comes from the TV. No satellite signal is linked to the box.
Avatar for Beaniesghirl
Hi @Beaniesghirl
