Discussion topic: Sky mini box not working - remote control doesn’t work and it won’t connect to the main box - intern
Message posted on 02 Aug 2023 12:22 PM
Sky mini box isn't working - no response from remote and can't join main sky Q box - internet is fine & rebooted
Message posted on 02 Aug 2023 12:30 PM
Re: Sky mini box not working - remote control doesn’t work and it won’t connect to the main box - in
I have the same issue. Message on tv connected to mini sky q box reads Sorry, because of a technical issue, you're currently experiencing a limited service. Please be assured that we're working hard to fix the problem.
Message posted on 02 Aug 2023 12:55 PM
Hi @Tiki-Taka
Have you tried pressing the Standby button (Amber led) on the front of the mini box.
If this turns the mini box on
Try completly resetting your mini Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Message posted on 02 Aug 2023 12:57 PM
I've just turned my tv and sky q box off at the electrical socket and back on and this has cleared the issue.
Message posted on 21 Sep 2023 08:48 PM
@oldfella, rosolved my remote issue!, thanks for your input!
Message posted on 09 Feb 2024 02:46 PM
The BT re code worked for me, totally crazy no updates made on TV or Q ... unless hidden in background batteries ok.
thanks
Message posted on 11 Apr 2024 08:17 PM
Sky q won’t work or connect to remote
@Tiki-Taka wrote:Sky mini box isn't working - no response from remote and can't join main sky Q box - internet is fine & rebooted
To is coming on but the remote won't connect
Message posted on 12 May 2024 10:48 PM
Thank you!
Message posted on 02 Nov 2025 06:58 PM
Come back from Holidays and my sky remote is not working
