06 Nov 2023 07:33 PM
06 Nov 2023 07:40 PM
@Craig17 wrote:
- Mini box not working. No Internet on main box
Hi @Craig17
First step you need to get your main Q box connected to the internet.
Try first rebooting your broadband router dy disconnecting the power lead for 30 secs and then reconnecting.
Wait until the router is completely back up and running and then reboot your main Q box.
If the main box is still not connected to the Internet Try a Network Reset found in main Q box Home - Settings - Setup - Network.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
06 Nov 2023 07:51 PM
Thanks. That seems to have worked
06 Nov 2023 08:02 PM
Hi. The internet connection came back on and now has gone off again
06 Nov 2023 08:03 PM
06 Nov 2023 08:08 PM
Posted by a Superuser, not a Sky employee. Find out moreHi @Craig17
Did you try the Network Reset or just the reboot?
06 Nov 2023 08:09 PM
Both. The WiFi is working. I can see it on my phone
06 Nov 2023 08:11 PM - last edited: 06 Nov 2023 08:16 PM
Posted by a Superuser, not a Sky employee. Find out more06 Nov 2023 08:12 PM
BT .......
06 Nov 2023 08:19 PM
@Craig17 wrote:
BT .......
Assume you used the SSID and password for the router 2.4 Ghz band @Craig17
Also have you tried turning off Smart setup in the BT router
https://www.bt.com/help/broadband/what-is-smart-setup-on-the-bt-hub--how-can-i-turn-it-on-and-off-
