Discussion topic: Sky mini box not connected to tv
Message posted on 14 Dec 2024 04:34 AM
Message posted on 14 Dec 2024 11:32 AM
Re: Sky mini box not connected to tv
Can the TV display other sources ok?
is it on the right hdmi input?
is the power light on the mini green?
Message posted on 14 Dec 2024 11:55 AM
@Keels wrote:
Hi. I've plugged every in. Connected sky mini box to tv but nothing is happening. Can anyone help please?
Hi @Keels
Reboot the mini as above.
