Discussion topic: Sky mini box keeps temporarily pausing - Sky unable to fix, unable make an engineer appointment.
Message posted on 11 Aug 2024 09:38 AM
My mini box keeps temporarily pausing and at worst - blue screening. Happening for over 10 weeks. Sky service has been awful. I've lost count of the phone calls, the number of times I've repeated my security details, the transfer through to the wrong department. I need an empowered person who can own this to contact me and ensure we get to a resolution. I am paying for a service that I am not receiving.
Message posted on 11 Aug 2024 09:43 AM
Re: Sky mini box keeps temporarily pausing - Sky unable to fix, unable make an engineer appointment.
Hi @Mint64
Reboot the mini as above.
