Discussion topic: Sky mini box keeps freezing after trying sky glass
This message was authored by: Dexter+Bruce
I have Sky Q multiroom. Everything was working perfectly until a couple of weeks ago we tried sky glass which in our area the speed was as issue so we went back to our trusty sky q. Now we have issues with the mini box which keeps freezing. This never happened before we tried glass. It is getting  nightmare to watch. We have tried the reset etc but to no available. This box is also closer to the hub (next room). The main box we have no issues and is further away from the hub. Can anyone help
Re: Sky mini box keeps freezing after trying sky glass
Hi @Dexter+Bruce
Who is your Broadband supplier ?
Unless it's Sky the mini has to connect to the main Q box WiFi and cannot connect to 3rd party routers.
Avatar for Dexter+Bruce
SKY us broadband supplier, we had no issues before going to sky glass, when that didn't work we we back to sky q when we had issues
Hi @Dexter+Bruce
Reboot the mini as above.
You will be asked to press the WPS button on the main Q box (not the mini).
As you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box
It is Sky broadband
