16 Jan 2025 04:34 AM
There has been a problem finding my sky Q box on the network does this every night I have to go down and turn on my TV and sky Q box so the mini box can reconnect this is a big problem for me sick of doing this makes me not want sky
16 Jan 2025 10:21 AM
Try completely reconnecting the mini.
Reboot the mini as above.
16 Jan 2025 10:51 AM
I've tried this process multiple times same thing happens
