Discussion topic: Sky mini box isn’t joining network showing error code mr102 and WiFi isn’t working either
This message was authored by SharonAnderson This message was authored by: SharonAnderson
Sky mini box isn't joining network showing error code mr102 and WiFi isn't working either
Re: Sky mini box isn’t joining network showing error code mr102 and WiFi isn’t working either
Hi @SharonAnderson
The mini will only connect to your WiFi network if on Sky Broadband.
On 3rd party Broadband it connects to the main Q box.
Reboot the mini as above.
