Discussion topic: Sky mini box is not working with sky Q
This message was authored by: Sammulla
I just had sky router put in yesterday. The engineer sorted out yhe main dky Q box. But i gave not been able to
link my mini box to sky Q box.
Re: Sky mini box is not working with sky Q
Hi @Sammulla
Reboot the mini as above.
