Discussion topic: Sky mini box intermittent and broadband connection intermittent
Message posted on 08 May 2024 05:59 PM
Hi,
For a few months the sky mini box has been very intermittent due to the main box losing connection.
The broadband we use is Vodafone and there has never been an issue with this.
it's got to a point we've had enough as we've had engineers previously who have 'fixed' the problem. However with a new box after a few months the same issue has come back
Message posted on 08 May 2024 06:59 PM
Re: Sky mini box intermittent and broadband connection intermittent
@CashMoneyHabs wrote:
Hi,
Try a complete reset of your system.
On 3rd party broadband and your router does not have a reset button, reboot it by disconnecting the power lead for 30 secs and then reconnecting.
As you are on 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
if you get the main box up and running try a Network Reset on the mini.
Message posted on 23 May 2024 10:33 AM
its pathetic I have been withour service for 2 months unless you are with Sky you cannot connect your sky Q! AND NO ONE will help!!
