29
This discussion topic has been answered Discussion topic: Sky mini box in summer house!
This message was authored by: Smithaam
I have 2 mini boxes, one in bedroom and one in summer house.
Unfortunately the one in summer house has really poor connection.
I don't have sky internet.
What can I use to boost the signal into the summer house? Can I use a normal wifi booster?
I do have an cat6 cable running into the summer house as was going to use this for a access point but don't believe this will help with the sky TV.
I could wire my main box directly with the rooter but believe this will loose the wireless signal to the box upstairs!
Thanks for any advice
This message was authored by: nigea99 Answer
Re: Sky mini box in summer house!
hi @Smithaam
The first thing you need to be aware of is that, as your home wifi is not SKY the minis do not use your wifi but a wfif signal generated by the main box.
If you can connect the main box to the router and the mini in the summer house to the router this should work - provided the mini in the summer house is connected to the ethernet directly or via a non-managed switch.
I think the mini in the house should be OK providing you don.t switch off the wifi on the main box
(edit : if your main box is connecting via wifi now you probably will need to do a netwrok reset on it after connecting via ethernet)
This message was authored by: Fergus+MacRoth
A few years ago (during lockdown) I installed a birdbox camera on the rear of our shed. It was a wireless camera. The signal was terrible and kept dropping out.
A purchased a TP-Link AC1200 wireless access point.
That boosted the signal dramatically all over the garden, and the camera was fine after that - right up until the time the resident Great **bleep** pulled the antenna off.
After that, I went with a wired connection to give me something to do while locked down.
FM
I didn't swear in that last post. You can guesss the word of the bird in question.
The AC1200 is available on Amazon, amongst other places, and is perfect for garden wi-fi.
FM
Avatar for Smithaam
Level 2 icon
I'm not worried about the WiFi, it's the sky tv I'm struggling with! I wanted to know if just a normal booster with help with the connection between the sky main box and mini box.
Could also use a mesh system to boost the WiFi but again will this boost the sky tv signal
Cheers
And incidentally, our minibox is in another room, but dropout was a problem even there. I hardwired the minibox and it has been fine ever since. If you have that option, I'd go with that.
FM
Sorry, I was merely pointing out that a stronger signal definitely helps, but that wired is best if you have that option.
FM
hi @Smithaam
Avatar for Smithaam
Level 2 icon
thank you, will try this out and let you know.
Avatar for Smithaam
Level 2 icon
It works for a few minutes but as I have seen on many other threads the sky boxs (main and mini) keep connecting back to the wifi!
Is there anyway to use a booster just for the TV signal or can this only to be used if you have sky internet???
You might get away with a SKy booster linked to the wifi from the SKY Q boxes but positioning is critical & I would say not that likely to cure your problem
As my expertise in this area is limited, I hope he doesn;t mind but I will tag @oldfella who is more experienced in this area & hopefuilly can advise.
Hi @Smithaam
First connect the Ethernet between router and main Q box and then carry out a Network reset on the main Q box.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect wired to router. (Do not carry out any WPS).
just wait for the main Q box to connect.
If it doesn't connect there is an issue with your Ethernet.
(Assuming the Q box will connect) connect another Ethernet cable between the router and your Summerhouse mini.
Then carry out a Network reset on the mini.
Network Reset found in mini box Home - Settings - Setup - Network.
Again do not do any WPS and just wait for it to connect.
If it doesn't connect there is an issue with the Ethernet.
As soon as it connects go immediately into the mini box hidden menu and turn off WiFi.
To enter hidden menu press Home in the mini menu and navigate down to Settings but do not select Settings.
Go to Network to turn off both bands of WiFi. Confirm before exit.
This message was authored by: lpardoe
I am going to try this as I have a similar problem. My only concern is, I have a mini upstairs connected via WiFi. Will that still work ok? Summer house will be wired via ethernet and mini upstairs will be WiFi.
Also.. for me to get a mini working in the summer house (via ethernet).. does my main box and router need to be connected via ethernet? Or can that be WiFi? (Virgin broadband and third party router).
Any help would be amazing @oldfella thank you.
Avatar for Smithaam
Level 2 icon
The way I sorted it was have a extra nodes running a mesh system and plug the sky q boxes into them and then also have an extra node wired vire into the summer house and sky q box wired into that.
You can not have one box wired and another work off WiFi unfortunately.
Hi mate thanks for reply. What does node mean sorry?
I have a mesh WiFi system in my house. I have 4 additional routers scattered around the house, one of which is in the summer house. Do you mean plug it all into those?
hi @lpardoe
On 3rd party broadband if you want to connect a mini by Ethernet to your router then all Q boxes must be connected by Ethernet to your Router.
If you cannot do this then the only option is to connect the mini by Ether to the main Q box.
You would need to turn off the WiFi on the Ethernet mini
