Discussion topic: Sky mini box has no signal just a blank blue screen
This message was authored by: BENCLEWS
Screen is just blue on my mini box and say it has no signal
Re: Sky mini box has no signal just a blank blue screen
Hi @BENCLEWS
Reboot the mini as above.
@BENCLEWS is the message no signal or no satellite signal
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
