Discussion topic: Sky mini box freezing, tried teset button but not cleared the issue
Message posted on 21 Jul 2023 04:25 PM
Cam the mini box be replaced for free
Message posted on 21 Jul 2023 04:27 PM
Re: Sky mini box freezing, tried teset button but not cleared the issue
@Gazza1105 Your post has been moved from the email forum as it's not an email route to Sky Customer services but a forum for Sky/Yahoo email related issues.
Message posted on 21 Jul 2023 04:42 PM
Hi @Gazza1105
Mini freezing is normally due to poor connectivity and not a box fault.
Reboot the mini as above.
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. Make sure that you press the WPS button on the Sky Router and not the reset button.
