Discussion topic: Sky mini box causing wifi connection issues on other devices
Message posted on 31 Aug 2024 07:20 PM
We recently had sky Q installed with main Q box downstairs and 2 mini's one in another room downstairs and the other upstairs.
We already had sky broadband and the hub is in the halway in the centre of the house
Problem occured straight away, any devices like tablets mobiles being used upstairs etc keep losing connection to wifi.
If we unplug the upstairs mini box the problem disappears and the devices work ok.
I did find the following info-
"Whether you have broadband from Sky or not, you can use your Sky Q mini boxes as WiFi hotspots. If you have your broadband from Sky, this is automatically set up. If you don’t have your broadband from Sky, you will need to turn this feature on. This will boost your WiFi coverage in your home and will enable your devices such as tablets and smart phones to connect to your WiFi if you have areas in your home where WiFi coverage might not be as good."
I have checked the settings but found no mention of said hotspot feature.
Both 2.4 GHz and 5 GHz are active on hub as well as sky Q box
Appreciate any help thanks
Message posted on 31 Aug 2024 07:28 PM
Re: Sky mini box causing wifi connection issues on other devices
Hi @Nero6
You will not find any Mention of Hotspots in the Q box settings if you are on Sky Broadband. WiFi Hotspots are automatic on Sky Broadband as they are generated by the Q boxes Mesh Network which is also the same as the Sky Router WiFi .
You could try completly resetting the mini boxes connection s follows:-
First reboot the main Q box and then when this is completely back up and running reboot the minis.
Reboot the minis as above.
If the mins still don't connect reliably try a Network Reset on the minis. Start with the one nearest to the main Q box
As you are on Sky Broadband and if the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router if on Sky Broadband or previously connected mini).
Message posted on 01 Sep 2024 05:31 PM
Thank you for the quick reply, I will give it a try. (fingers crossed)
