Discussion topic: Sky min box red Led on. Won’t turn on
This message was authored by: AndyLondon42
Sky mini box stopped working.  Removed power. Waited 10 seconds.  Plugged back in.  Red led came on for a second or two then went out.  Same thing kept on happening.  Powered up, pressed the reset button, Red led on all the time.  Front buttons and remote do nothing.  It's is knackered ?
Re: Sky min box red Led on. Won’t turn on
Hi @AndyLondon42
Check through the following link .   If you cannot solve your issue it will lead to a conclusion
https://www.sky.com/help/articles/sky-q-box-wont-turn-on-t2
Avatar for AndyLondon42
Level 0 icon
Remote is working.  Nothing on the tv screen. Red led on and Red led showing showing through optical out socket.   The unit has power. Red led perm on. Front panel buttons do nothing. Remote does nothing.
As I said @AndyLondon42 .
If you work through the link I posted and cannot solve your issue it does give a conclusion.
