Discussion topic: Sky main box is working but multi room box is showing no satellite signal?
Message posted on 06 Apr 2024 06:00 PM
My sky main box is working but the my multi room box is showing no satellite signal, its all showing connected but just no signal.
Message posted on 06 Apr 2024 08:21 PM
Re: Sky main box is working but multi room box is showing no satellite signal?
Try a Reset Settings in the main Q box hidden menu.
