Discussion topic: Sky keeps pausing, not recording programmes, running very slow when you press a command, not tewindi
This message was authored by Loz19721 This message was authored by: Loz19721
Sky keeps pausing, running slow, doesn't react when pressing buttons
Re: Sky keeps pausing, not recording programmes, running very slow when you press a command, not tew
Hi @Loz19721
First reboot your Q box.
Then try a Reset Settings in the Q box hidden menu.
Loz19721
Hi
I have reset and now it won't turn back on
