3
This discussion topic has been answered Discussion topic: Sky keeps losing signal
This message was authored by: Beverley53
For the past 3 weeks my sky signal has been dropping in and out frequently and losing the picture for a few seconds, sometimes the picture distorts and it is impossible to watch the programme. I have tried it on a range of different channels from BBC to Sky channels themselves and I still get the same issue.
This message was authored by: Mark39 Answer
Re: Sky keeps losing signal
You've posted in the Sky+ forum. I'll move your post to the correct forum.
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
Please Note: Sky+ is now a legacy service that Sky are replacing with their newer services: Sky Q (all issues will be fixed during a Sky Q install), Sky Glass and Sky Stream
I am NeurodivergentMy Sky FAQs: Glass Stream Go Plus
Avatar for Beverley53
Level 0 icon
We have tried all of the cables coming out of the box and have also reset the box to see if that would fix the issue but it still seems to keep happening, we have Sky Q installed already we have had it for a few years now. We do also have sky protect
