Discussion topic: Sky keeps going blank and the message on screen says “out of range”. I’m using an HDMI input.
This message was authored by: Alex32
It's either snowy or blank. Does anyone know why this is happening? Sometimes the picture just comes back.
tried a reboot but still happening.
Re: Sky keeps going blank and the message on screen says “out of range”. I’m using an HDMI input.
Hi @Alex32
First make sure that the TV is switched on and is switched to the HDMI input to which the Q box is connected.
Then with the Q box switched on with green led illuminated
Press
Home 1 0 8 0 Home
on the Q box remote control.
This will change the Q box to standard resolution which should work for all TV’s.
Avatar for Alex32
Thank you so much
@Alex32 wrote:
Thank you so much
Did that work @Alex32 ?
