Discussion topic: Sky keeps freezing. I've switched off for 20 mins, twice, today. Still unwatchabley
This message was authored by: 57
Every channel works for a few minutes then freezes
Re: Sky keeps freezing. I've switched off for 20 mins, twice, today. Still unwatchabley
Hi @57
