Discussion topic: Sky keeps dropping connection to EE broadband
This message was authored by: Jmh04
Just got EE broadband installed and it is great apart from sky connecting to it .. problems with main Q box and mini.. is this a ploy by sky to make you take their broadband as everything else in the house works perfectly with it
Re: Sky keeps dropping connection to EE broadband
The Q to Q connectivity doesn't use your broadband.
It creates it's own 5GHz network (Ch 36 with 80MHz default) - if it's disconnecting then it's likely your EE router is broadcasting at overlapping frequencies.
Ensure your router is configured to avoid channels 36 to 48.
Also, the main Q box will no longer connect over 5GHz and will only use 2.4GHz.  Ensure there's no steering enabled as this will cause disconnects too.
Avatar for Jmh04
I can watch tv fine but can't get access to anything that requires broadband - on demand etc
How do I check my router for those settings ??
Via the router's admin page.
Avatar for Jmh04
Thanks - tried that - still not working
will phone sky when I have 3 hours to spare
Hi @Jmh04
Assume you don't have the option to connect by Ethernet?
Avatar for Jmh04
No - too far away
@Jmh04 wrote:
No - too far away
Hi @Jmh04
You could consider trying Powerline Adaptors.
