Discussion topic: Sky issues and no tnt sports
This message was authored by: Dsw9
TNT sports won’t work on main box or 2x sky q boxes. Boxes keep loosing signal and other numerous channels aren't working due to it says satelitte issues. I suggest an engineer comes over to soty
Re: Sky issues and no tnt sports
@Dsw9
If a message displays “no satellite signal” firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s likely to be a dish alignment issue so check the troubleshooting in this link
If you are connected to a communal dish you need to liaise with your building management company / landlord who will have their approved engineers to contact.
Remember, a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
▪️I AM NOT A SKY EMPLOYEE ▪️
