Discussion topic: Sky in shed
This message was authored by: Lyn32
Sky in shed
I am wanting to put sky in my shed I have Sky Q in my house
can this be done please
Re: Sky in shed
Depends how far away your shed is to do it wirelessly.
Avatar for Lyn32
Re: Sky in shed
Thankyou it's about 12 Mtrs from main house
Re: Sky in shed
Probably too far.
Do you currently have a Q mini?
Avatar for Lyn32
Re: Sky in shed
No I don't
would that work if I got one
thankyou
Avatar for Lyn32
Re: Sky in shed
Thankyou
No I don't have a Q mini
Re: Sky in shed
Hi @Lyn32
You would need a Multiscreen subscription (full price £15 a month) and a Mini box. Don't assume that a Mini box automatically comes with a Multiscreen subscription, request one at the same time. May cost you £50 admin fee on the loan.
Unless you have Sky broadband, the distance is from the Sky Q Main box to the new Mini box that matters. You may have to run a Cat5e+ cable between the Main box and Mini if the WiFi doesn't reach.
Avatar for Lyn32
Re: Sky in shed
Thankyou so much for that information I do have sky broadband so I'll call them to get multi room and a mini box
hopefully that will work
thanks again Lyn
Re: Sky in shed
Hi @Lyn32   Note it is called Multiscreen. Multi room is/was an old Sky+HD term. Does the Sky WiFi work in the shed?
Avatar for Lyn32
Re: Sky in shed
Hi
Apologies
thankyou. I've never tested it I will have to go in the shed tomorrow and try it hasn't been converted yet but don't want to spend money getting the she'd converted if I can't get sky and wIFi
Re: Sky in shed
Important to note that if the conversion involves foil-laminated foam insulation, as is typical, you might well find that WiFi which worked before this was put in doesn't do so afterwards.  Running ethernet cable in with a mains power connection is almost always preferable to wireless over a distance and through external walls.
Avatar for Lyn32
Re: Sky in shed
Thankyou
im really clueless when it comes to this sort of thing
I appreciate your help
