Discussion topic: Sky in my sited caravan.
Message posted on 22 May 2023 05:26 PM
Hello, does anyone know if it is possible to have sky q in my sited caravan without taking the sky q box back and fore?
Message posted on 22 May 2023 05:33 PM - last edited: 22 May 2023 05:40 PM
Re: Sky in my sited caravan.
'taking the sky q box back and fore' is a breach of the terms and conditions in the Q contract* and so isn't something which can be discussed here
Having a legitimate separate Q subscription at the caravan (with its own loaned hardware there) is possible, but only if the caravan has a unique existence on the Royal Mail Postcode Address File.
*actually it's moving the Viewing Card which isn't permitted, but a Q box has no functionality without a card.
Message posted on 22 May 2023 05:48 PM
Hi, thank you for your reply. I am not looking to break any rules so this is not an option I will be looking in to, thank you.
Message posted on 22 May 2023 06:09 PM
No problem. The legitimate way to access some of the features of a Q subscription away from the registered address is through the Sky Go app.
Message posted on 22 May 2023 06:12 PM
Is there a way of playing sky go through the TV? If not I'm going to stick with my firestick
Message posted on 22 May 2023 06:18 PM
@Tran1234 wrote:Is there a way of playing sky go through the TV? If not I'm going to stick with my firestick
There is an official Sky Go app available for consoles (Playstation & XBox) and for Apple TV boxes. You need to have a multiscreen subscription for it to function though.
Message posted on 22 May 2023 06:54 PM
You can use a laptop again you need multi room and a HDMI connection.
Message posted on 22 May 2023 06:56 PM
When you say multi room, do you mean sky boxes in other rooms, as, apart from the living room I have mini boxes in 3 bedroom's? Thanks
Message posted on 22 May 2023 07:10 PM
@Tran1234 In that case you'll have a multi room sub also.
