2
This discussion topic has been answered Discussion topic: Sky in Garden Room
This message was authored by: JJ9991
Sky in Garden Room
I currently have Sky Fibre and a sky router. I also have a main sky Q box and a sky mini box (bedroom) connected to the router via wi-fi.  I'm currently having a garden room built and would like another sky mini box in there, however the WiFi doesn't reach.
 I'm assuming I can just run an ethernet cable out to the room from the house? If so, is this from my main sky box or my sky router?
Thanks!
This message was authored by: Laing1 Answer
Re: Sky in Garden Room
Thanks!
@JJ9991 you can use either so which ever one is the closest to the garden room or which ever one its easiest to run an ethernet cable from
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Thanks!
Avatar for JJ9991
  • Thanks!
Answered - Go to Answer
