3
This discussion topic has been answered Discussion topic: Sky dish no reception due to neighbours scaffolding. Would Sky Stream be answer?
This message was authored by: HMP17
Have Sky Q and neighbours building works / scaffolding means we've had no signal for weeks. Cant even get Apps now. Nothing. Thinking of switching to Sky Stream. Would this solve the issue as it doesn't require a dish?
This message was authored by: nigea99 Answer
Re: Sky dish no reception due to neighbours scaffolding. Would Sky Stream be answer?
hi @HMP17
Yes you could switch to SKY Stream but note it is a different product in several ways and does need a good internet connection.
Unfortunately SKY Q does need a periodic 'Keep alive' signal which is sent via Satellite which is why apps & catch up cease.
You should be able to use SKY Go whilst you wait for the scaffolding to be removed
hi @HMP17
@HMP17
In the short term have you asked your neighbour how long the scaffolding will be up for?
Avatar for HMP17
It will be a good 6 more weeks or so yet.
