Discussion topic: Sky devialet sound box not turning on
Message posted on 07 Nov 2023 05:56 PM
I've had a sound box with our sky q for a few years and love it. For some reason it won't turn on, it has power as the red light is on it just wont turn green when I press the power button in the remote or the top of the box!?
any help would be greatly appreciated
Message posted on 07 Nov 2023 06:04 PM - last edited: 07 Nov 2023 06:06 PM
Re: Sky devialet sound box not turning on
Apparently there's a reset option: use at your own risk.
Restart your Sky Soundbox
- Switch off the your Sky Soundbox at the mains
- Make sure the LED light has gone out (this can take about 6 seconds)
- Switch your Sky Soundbox back on at the mains
Still having problems? Try re-setting it instead:
- Switch off the power to your Sky Soundbox at the wall and wait for the lights on the front panel to go off
- Press and hold down the power and volume down buttons together. Don’t release them
- While you’re holding down the buttons, switch the power back on at the mains
- Keep holding down the power and volume down buttons for at least 10 seconds until the red light on your Sky Soundbox comes on and then changes to amber
- Release the power and volume down buttons
- After 5-10 seconds, your Sky Soundbox will make the boot-up sound and turn itself back on. The light will go green
Message posted on 04 Feb 2025 07:47 PM
Mine deviatet is still on orange. Nothing can get it out of this ! I'm guessing it's ready for the skip?
Message posted on 04 Feb 2025 09:57 PM
Unfortunately the Soundbox is long out-of-support from Sky. It might have some value as a non-working device on eBay for the drivers alone.
