Discussion topic: Sky channels change colour frequently and the sound also turn off when the colour changes.
This message was authored by: Tutu1
My screen channels change colour frequently and the sound also turn off when am watching Sky TV. This only occurs when am on sky and not when l watching Netflix or YouTube.
Re: Sky channels change colour frequently and the sound also turn off when the colour changes.
Sounds like your dish alignment.  You may need to call Sky to get an engineer to check it (assuming you have your own dish)
Hi @Tutu1
Might be worth trying a Reset Settings in the Q box hidden menu.
Avatar for Tutu1
Thank you! I will give your advice a try.
