Discussion topic: Sky channels and recordings
This message was authored by: mcgillivary
I am unable to access the recordings or any channels
Re: Sky channels and recordings
Hi @mcgillivary   Have you tried power rebooting your Main Sky Q box? Are you seeing any error messages?
Hi @mcgillivary
Assume you have tried rebooting your Q box?
If you are getting any hard drive messages or cannot make new recordings
https://www.sky.com/help/articles/sky-q-hard-disk-error-messages
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box.
